Date/Time: Tue, 25 Feb 2025 13:38:11 +0000
Completed Denali Setup - Data Feed still delayed
View Count: 554
[2021-04-15 01:28:36]
User107899 - Posts: 2
I followed the Denali feed setup instructions to activate the Denali data feed & exchanges, however my data is still showing up as delayed. I don't know what to do next to remedy. Please advise.
Thank you.
[2021-04-15 02:10:49]
The reason you are not getting real-time data from the CME Group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees.
Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees:
If you do not have a funded trading account or one with a supported trading service, then refer to this solution:
Easy Solution to CME Funded Trading Account Requirement
We recommend using the above solution in any case to avoid this problem in the future.
