Date/Time: Mon, 22 Jun 2026 13:28:27 +0000
Multiple Volume Profiles on DOM
View Count: 7594
[2021-04-15 01:14:26]
AndyB - Posts: 111
I have already figured out how to do different time frame volume profiles on the DOM, ie Daily and 30 minute. What I am trying to accomplish though is to have the current 30 minute profile on one side, and the previous to the left. I can not figure out a way to make this happen. I can do an hourly profile on one side, but every hour they will both reset completely, and id like to still have that previous volume profile up. Any Help would be greatly appreciated. Thanks
[2021-04-15 14:17:33]
John - SC Support - Posts: 46802
In order to have the previous period displayed, you would need to manually set the times for that VbP and update it when the next period starts. Refer to the following Period Type:
Volume By Price Study: One Period from Start Time to End Time
In terms of having multiple profiles, you would have to do the following for at least one of the profiles (it might be easiest to do it for both):
Volume By Price Study: Right Aligning Volume Profiles with Space on Right Side of Chart
[2021-04-15 14:20:51]
AndyB - Posts: 111
Ah, ok. So there’s no way to have the profile reference “n” periods back?
[2021-04-15 16:05:29]
So there's no way to have the profile reference "n" periods back?
No, not for the Volume by Price study on a Trading DOM.
[2021-04-15 16:17:01]
AndyB - Posts: 111
Thanks for your replies. One last thing (and I know this probably isnt the right way to screen shot but I am not sure how to take a screenshot of a DOM via Sierra Chart)
The arrow is pointing to a volume profile I set up with the minimum width set to 100% and to show bid/ask volumes relative to eachother per price. is there a way for me to center the bid/ask numbers to more closely resemble footprint? I hope this question makes sense. you can see how the volume numbers are a little off in their alignment.
imageDOMScreenshot.JPG / V - Attached On 2021-04-15 16:16:48 UTC - Size: 75.56 KB - 455 views
[2021-04-15 16:37:57]
There is the following Input for the VbP study, but it does not apply to the VbP on the Trade DOM:
Volume By Price Study: Align Volume Numbers to Base of Volume Bars
