Date/Time: Thu, 24 Sep 2026 15:58:23 +0000
Multiple Setup ?
View Count: 750
[2021-04-14 23:55:13]
User893178 - Posts: 1
Hi, do you support multiple setup ? FYI, I am now in free version.
I installed 2 setup, it was fine for first day, but just after it started to crashing and closing by itself.
Is there any limitation to install and run more than one setup, in both technically and commercially ?
FYI. I am trading Binance Futures only.
[2021-04-15 14:06:07]
John - SC Support - Posts: 47996
The specific information on multiple installations can be found here:
Sierra Chart Purchase and License Information: Licensing / Number of Systems
You will see that you are allowed to run on 2 different computers at the same time without any issue.
But, even if you have 3, it just means that you will not be able to use the third system. It should not be crashing.
We need more information on exactly what happened and how you are setup and which installation is crashing, or if it is both.
Also, try running in Safe Mode to see if that resolves your issue. Refer to the following:
Sierra Chart - Software Login Instructions: Using Safe Mode
