Date/Time: Tue, 25 Feb 2025 13:09:44 +0000
SMS alerts stopped working
View Count: 676
[2021-04-14 23:05:42]
User566851 - Posts: 20
Hello:
My sms alerts have stopped working. I am wondering if the issue is on the SC side or my side? Alert log shows that the alert is being triggered and that everything is working. Could there still be an issue with the sms provider?
Thanks.
[2021-04-15 13:50:03]
John - SC Support - Posts: 38150
Copy and paste your message log after the system is supposed to have sent an SMS. We want to see if there is any kind of error in the log. Follow these instructions:
https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#log
[2021-04-15 13:57:40]
Software version: 2239 64-bit | 2021-04-15 06:55:32.590
Primary Thread ID: 11740 | 2021-04-15 06:55:32.590
Usage end date: 2021-10-08 | 2021-04-15 06:55:32.590
Enabled for: Advanced Features 2. | 2021-04-15 06:55:32.590
Enabled for: Sierra Chart Historical Data Service. | 2021-04-15 06:55:32.590
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-04-15 06:55:32.590
Enabled for: Delayed Denali Exchange Data Feed. | 2021-04-15 06:55:32.590
Enabled for exchange2: CME (Trading Account Required) | 2021-04-15 06:55:32.590
Enabled for exchange2: CBOT (Trading Account Required) | 2021-04-15 06:55:32.590
Enabled for exchange2: COMEX (Trading Account Required) | 2021-04-15 06:55:32.590
Enabled for exchange2: NYMEX (Trading Account Required) | 2021-04-15 06:55:32.590
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-04-15 06:55:32.590
Current selected Data/Trading service: CQG WebAPI | 2021-04-15 06:55:32.590
Custom symbol settings values: enabled | 2021-04-15 06:55:32.590
Chart Update Interval: 500 | 2021-04-15 06:55:32.590
Intraday Data Storage Time Unit: 0 | 2021-04-15 06:55:32.590
Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-04-15 06:55:32.590
2021-04-15 13:55:32 Local computer time in UTC | 2021-04-15 06:55:32.590
2021-04-15 06:55:32 Local computer time in SC Time Zone | 2021-04-15 06:55:32.590
2021-04-14 23:38:50 Server time in UTC | 2021-04-15 06:55:32.590
Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-04-15 06:55:32.590
Program path: C:\SierraChart\ | 2021-04-15 06:55:32.590
Data Files path: C:\SierraChart\Data\ | 2021-04-15 06:55:32.590
OS Version Number: 10.0 | 2021-04-15 06:55:32.590
Locale Setting: C | 2021-04-15 06:55:32.590
DLLs: CongestionFinder_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2021-04-15 06:55:32.591
Allowed protected custom studies: | 2021-04-15 06:55:32.591
Sierra Chart account data changed. Requesting updated account information. | 2021-04-15 06:55:53.917
Successfully processed Sierra Chart account data. | 2021-04-15 06:55:55.430
[2021-04-15 13:59:06]
Alert Log:
Chart Drawing Alert: F.US.EPM21/F.US.MESM21[M] 2000 Trades #8, Horizontal Ray #2109, Last (4142.75) Equal to (4142.75) | Bar date-time: 2021-04-15 06:55:44 | Alert: AlertSound (1)
Alert message successfully sent.
[2021-04-15 15:59:03]
Follow these instructions to use the Forced Login procedure:
Sierra Chart - Software Login Instructions: Forced Login
Then try again and if you still have a problem then we want you to go to the Sierra Chart website and Disable and re-enable the option for SMS messaging at this link:
https://www.sierrachart.com/UserControlPanel.php?page=SMS
Then try again and let us know if it is working or not.
[2021-04-15 16:44:03]
I completed both items. Still not working
[2021-04-15 17:36:28]
Then we do not know what the cause is. There is just some reason the SMS is not going all the way through the network, but we do not know what it is.
[2021-04-15 18:05:47]
I took a look at the last time I received a sms alert and it was February 2/28 I believe. Could it be related to the billing change somehow with AMP?
[2021-04-15 18:28:27]
No, this is definitely not related to the billing change. You have always been paying for the SMS messaging directly through us. And nothing has changed in our setup with the messaging.
We really do not know where the issue is.
