Date/Time: Tue, 25 Feb 2025 12:59:24 +0000
Study and details question
View Count: 1934
[2021-04-14 16:59:06]
User203962 - Posts: 9
Could someone tell me the name of the study which give a red or green circle to indicate buyers and sellers
refer to the image attached (there is an arrow to show one circle I am talking about).
Could this study be applied to for example a 5 mins Chart or it has to be on the DOM chart only?
imageImage_question_1.PNG / V - Attached On 2021-04-14 16:56:55 UTC - Size: 251.58 KB - 208 views
[2021-04-14 17:16:07]
Ackin - Posts: 1865
Try:
Large Volume Trade Indicator
Volume At Price Threshold Alert V2
Volume at Price Threshold Alert V2
[2021-04-15 20:31:57]
Thank you
[2021-04-15 20:40:49]
is there another study you can recommend which is used to tell if a big buyer or big seller got filled at the current price?
[2021-04-15 21:13:10]
Ackin - Posts: 1865
I wrote you the two main ones from the Sierrachart default studies list. Next 40 Numbersbars studies is also on CZSK forum. You can also try to look at it ....
contact link:
