Date/Time: Tue, 25 Feb 2025 13:18:59 +0000
account activation pack 5 with real time datas
View Count: 532
[2021-04-14 16:12:34] |
User151274 - Posts: 3 |
goodmorning i'm trying a new trial account with all permits. now i would like to transform the trial account in a real account with pack num 5 with realtime datas from EUREX and CME. i'm a NON PROFESSIONAL USER and i'm choosing a broker to open a new trading account for futures. As soon as possible i will tell you the id account. do you confirm that the cost are 21+10,90 usd? can you tell me if is the procedure correct or how i should menage it? thanks a lot in advance |
[2021-04-14 16:58:06] |
John - SC Support - Posts: 38150 |
The exchange fees are $25.00 for the EUREX and $10.40 for the CME With Market Depth. But refer to the following table for the CME Group exchange options, as there is a wide range of prices depending on what you need: Denali Exchange Data Feed: Supported Exchanges (Exchange Fees) You will also pay an additional $10.00 in your Package cost for the Denali Exchange Data Feed Fee. This will be done when you change your Package from Package 5 to Package 11 as is called out in the Setup Instructions. Once you have your trading account, then follow the instructions at the following link to get setup for the CME Data: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* And then follow the instructions at the following link to get setup for EUREX data: https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_EUREX For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-14 17:19:11] |
hi john and thank yuo for your kind reply. the price you wrote are for a trading account c/o a broker supported by sierrachart. is it right? not forany kind of broker? have a good evening. andrea |
[2021-04-14 17:41:56] |
You do not need a broker for the EUREX, so that price would be the same. For the CME with Market Depth, without a trading account the cost would be: $115.00 per month You could also use the cheaper option of the CME E-mini, For professionals and users without a trading account exchange, which is $62.40 per month. We highly recommend getting a trading account setup, as you can see the costs for the CME Group are much higher without one. Refer to the following for one possible way to get an account setup for a minimum outlay: Easy Solution to CME Funded Trading Account Requirement For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-15 05:54:43] |
VERY NICE. I CHOSE AMP. NOW I 'WILL OPEN THE ACCOUNT AND THEN I WILL LINK WITH SIERRA CHART. HAVE A GOOD DAY ANDREA |
