Date/Time: Tue, 25 Feb 2025 12:57:55 +0000
Service Pack 5 fees
View Count: 483
[2021-04-14 16:11:33] |
User785886 - Posts: 1 |
Can I check that if I want to have Real-time data that the feed cost is included in the USD36 per month fee for the application. I am looking at the DAX GER30 for CFD's and I wanted to check that there are no extra costs that I need to consider. Thanks Chris |
[2021-04-14 16:53:26] |
John - SC Support - Posts: 38150 |
It depends on the data. The CFD and Forex data IS included with any Sierra Chart package. Other data is not. Refer to the following: Real-Time Data And also refer to the following if you really just need the CFD data: Sierra Chart Real Time and Historical Forex and CFD Data Service If you need any other data, then refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
