Date/Time: Sat, 04 Jul 2026 11:47:16 +0000
Feature request: backtesting multiple variables
View Count: 782
| [2021-04-14 15:39:10] |
| Matt NL - Posts: 91 |
Would it be possible, like with MT5, for backtesting ideas to have the option to input like a range for specific parameters? Then let the program run all the test and figure out what parameters work best? It's such a pain having to make little changes to each variable and write everything down on a piece of paper. Takes hours and hours (actually days and weeks). With MT5 you say "for variable A use range 1-2, for variable B use ranges 100-400" and specify also the steps in the range. Then press a button and it'll backtest all possibilities. Thanks Matt |
| [2021-04-16 20:06:46] |
| User61576 - Posts: 458 |
+1
| [2021-04-18 00:54:42] |
| Ticks - Posts: 212 |
Customers been asking for back testing of input variables for years. This feature will not happen. |
