Date/Time: Tue, 25 Feb 2025 13:31:46 +0000
Average
View Count: 448
[2021-04-14 15:28:40]
User361939 - Posts: 167
I am trying to create color background alert for "average range per bar" on e.g 15min chart
There is a study "Avarage Daily range" which would show exactly what i need but id works only for DAILY charts.
How can i get the same result but for "intraday" time frames?
Best Regards
[2021-04-14 15:44:49]
John - SC Support - Posts: 38150
It's easy enough to create the "Average Daily Range" for what you want. Just add the True Range study and then apply the Moving Average - Simple to the "True Range".
Refer to the following for the True Range:
True Range
Refer to the following for the Moving Average - Simple:
And refer to the following for how to base a study on another study:
Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study
