Date/Time: Mon, 25 Nov 2024 21:36:32 +0000
Tool Bar Action Lagging
View Count: 1047
[2014-03-07 13:39:42] |
Handle - Posts: 36 |
ver 1094 When clicking to change tools and particularly when changing/clicking on one of the tool configuration tabs ( TC ) in the toolbar I get a very slow response or no response for 10 to 30 seconds. Computer memory and CPU loads are all in the 35% range. Any ideas why this is happening. Long time user and don't recall this being an issue in earlier versions. Update: Issue persists. Click on a tool, then cant select a TC. For example: Select the marker tool, tool is enabled and can put it on chart. Quickly right click and brings up local menu and Chart Drawing Properties and I can make changes. But cant do it quickly via TC buttons. Please advise or if you need more info to diagnose Date Time Of Last Edit: 2014-03-07 15:39:31
[2014-03-08 03:53:56] |
It sounds like the CPU usage is too high for the Sierra Chart process. Refer to help topic 30: http://www.sierrachart.com/index.php?l=doc/helpdetails30.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-08 03:54:08
