Date/Time: Tue, 25 Feb 2025 23:38:12 +0000
no data in the three package
View Count: 574
[2021-04-14 07:28:08] |
Пользователь488020 - Posts: 100 |
Hello, I connected three charts with one login and password on one computer. All programs are running. But I don't have the data. why? How to fix it? I was faced with the fact that only two sierra charts are launched on one computer, there is no data on the third program, or then all three will stall! Is that right?
[2021-04-14 07:56:47] |
Ackin - Posts: 1865 |
Sierra Chart Support will not be handling any support requests here (User Discussion). If you want Sierra Chart Support to help you, please post your question on the Support Board here:
https://www.sierrachart.com/SupportBoard.php |
[2021-04-16 14:18:26] |
We see you are using the Denali Exchange Data Feed. Therefore, refer to: Denali Exchange Data Feed: Connections You will want to use the File >> New Instance feature to use sub instances. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-16 14:19:00
