Date/Time: Tue, 25 Feb 2025 13:04:00 +0000
can someone help me
View Count: 485
[2021-04-14 03:25:53] |
5staRScalper - Posts: 11 |
i cant trade, i cant get into my live account. i dont know what to do. can someone help please
[2021-04-14 13:32:37] |
John - SC Support - Posts: 38150 |
We need some additional information. You have posted to this support board with an active account, which we assume is the account you use with Sierra Chart, in which case, you should not have an issue logging into the Sierra Chart software itself. If you are having a problem logging into the Sierra Chart software, then you may be able to resolve your problem by resetting your password. You can do this from this page: https://www.sierrachart.com/PasswordReset.php If you are having a different problem, then we need to know the specifics of what you are seeing, including the exact wording of any error messages you are getting. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
