Date/Time: Sat, 26 Sep 2026 05:58:48 +0000
setup
View Count: 696
| [2021-04-14 03:25:08] |
| User973892 - Posts: 5 |
i have no idea how to set sierra charts up. im having lots of difficulties thank you
| [2021-04-14 03:34:31] |
Well the first thing we recommend you do is to go through the instructions here: Getting Started, Opening Charts and Basic Trading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
