Date/Time: Tue, 25 Feb 2025 11:34:50 +0000
How to login to the amp trading account via sierra chart?
View Count: 629
[2021-04-14 03:24:47] |
TOMASZ OLSZEWSKI - Posts: 1 |
[2021-04-14 03:39:54] |
Most likely AMP set you up on CQG. Therefore follow the instructions here: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
