Date/Time: Tue, 25 Feb 2025 13:43:21 +0000
[User Discussion] - scid File, Open as 0.0... replace with which value?
View Count: 477
[2021-04-13 21:23:35]
User681150 - Posts: 62
hello, i am doing analysis of the tick data through the scid file and have converted it BUT there appears 0.0 for the Opening price when 1 trade takes place (as per the link below) but my analysis includes analyzing the Opening price... is there a value that corresponds to the 0.0 opening price? (previous close, current low, etc, etc) id like to replace the 0.0 with the 'opening price' but what value should i use?
thanks for any guidance
intraday file specifics: Intraday Data File Format: Data Structures Used
[2021-04-14 03:33:02]
The last trade price in the Intraday record would also be considered the open price in the case of a one tick/trade record.
Date Time Of Last Edit: 2021-04-14 03:33:11
[2021-04-14 16:11:28]
thanks. it makes sense. but is the Open = 'last trade price' always the previous close?
i am including a screenshot of some examples of when the Open (as previous close) is higher then the current High and another for a 3-Trade that the previous close doesn't match the next Open.
just want to make sure i am using the right value when substituting the 0.0 on Open price. please provide more clarity. thanks
imagesierracharts_scid.png / V - Attached On 2021-04-14 16:08:46 UTC - Size: 22.76 KB - 190 views
