Date/Time: Mon, 14 Sep 2026 00:17:27 +0000
Text Colouring based on bid/ask imbalances
View Count: 982
| [2021-04-13 20:26:32] |
| steliosdrk - Posts: 22 |
Hi Guys. I can' figure it out.Iam propably dump. I want the text colouring to be based on diagonal dominant side ask/vol percentage. but when i change the Column 1 percentage threshold to .0, .0, .9 for example doesn't do any difference. I'll attach the chartbook. Thanks. |
| [2021-04-13 20:33:50] |
| John - SC Support - Posts: 47854 |
Refer to the description of that text coloring option here: Numbers Bars: Text Coloring Based on Diagonal Dominant Side AskVol BidVol Percentage Note that when you work through the math, you will always end up with a percentage value that is greater than 100. So a value of .9 for the highest percentage will not make any difference. You need to enter Percent Compare Thresholds that are greater than 1, such as 1.25, 1.5, 2.0. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
