Date/Time: Wed, 18 Nov 2026 14:24:04 +0000
Alert manager not populating log in SierraChart/Logs - pictures attached
View Count: 983
[2021-04-13 17:06:24]
HeyUgly - Posts: 289
hello
im trying to code a bot, i have the alerts going off all day long as you can see in the alert manager log
when i go to the Sierrachart/Logs , its not there. How do i know where this is going? i need to code the bot
to look where this .txt log is being written to all day
i followed the instructions, i installed this default {sierra} and have never moved it so the log should be in there. is there a setting that needs to be turned on?
imageunknown.png / V - Attached On 2021-04-13 17:06:14 UTC - Size: 91.77 KB - 397 views
[2021-04-13 17:11:09]
i see i can save the file to log
but does this write continiously? what i want to do is capture the log in real time and have my bot read it so it can send me the alert to my room, thats it.
this pic ive been able to save it, but will every new alert be populated to this file in realtime, or do i have to save it all the time for the alerts to poulate in the log file
what i really want is the alerts from the alert manager to be able to be captured in real time
imageunknown.png / V - Attached On 2021-04-13 17:11:08 UTC - Size: 114.81 KB - 308 views
[2021-04-13 17:13:47]
in this example, you can see the most recent TSLA alert is not written to the log automatically
so the bot wont be able to catch it and alert it.
is there a way to fix this?
imageunknown.png / V - Attached On 2021-04-13 17:13:41 UTC - Size: 140.19 KB - 338 views
[2021-04-13 17:51:26]
John - SC Support - Posts: 48570
Refer to the following setting:
General Settings Window: Save Alerts Log to File (Global Settings >> General Settings >> Log >> Log)
