Date/Time: Tue, 25 Feb 2025 11:44:37 +0000
real time data
View Count: 445
[2021-04-13 16:07:29]
User695019 - Posts: 32
Hello, how can I verify that I have real time data and not few minutes delayed data. thank you
[2021-04-13 16:40:51]
John - SC Support - Posts: 38150
Look in your Chart Header and look for the entry DD:. The time that follows that entry is the Data Delay and tells you how much your data feed is delayed in relationship to your local system clock.
If that item is not present, then refer to the following for how to add it:
Working With Charts: Region Data Line / Chart Header
