Date/Time: Mon, 25 Nov 2024 21:44:06 +0000
Euro Schatz - Net change problem
View Count: 1368
[2014-03-07 08:52:39] |
Marmany - Posts: 307 |
Rolled to FGBSM4 contract yesterday, and found incorrect data in Net Change column of a QuoteBoard. It currently gives a figure of -21991.605. Tried delete all data and download but the does not clear the problem. Using TransAct data and SC v 1094. Values for other Eurex commodities are correct. Please advise Date Time Of Last Edit: 2014-03-07 08:55:00
[2014-03-07 09:02:36] |
Try selecting File >> Disconnect and File >> Connect to Data Feed.
[2014-03-07 09:13:03] |
Problem persists after re-connecting to Data Feed
[2014-03-07 09:53:41] |
This is an issue that TransAct will need to resolve.
