Date/Time: Tue, 15 Sep 2026 15:44:11 +0000
DTCBridge.exe not found
View Count: 896
| [2021-04-13 13:21:18] |
| John Mc - Posts: 32 |
I am including the message log for analysis per the instructions in the message log. For some reason when I try to switch to a funded account I get the following message when I reconnect.
| [2021-04-13 13:31:40] |
| John - SC Support - Posts: 47898 |
You need to install the Rithmic Bridge files. You will find these here: Rithmic Bridge Files You also are having a problem with a 3rd party study. You are getting the following messages: Warning: The Custom DLL study "ETOFSv3_64.scsf_Unfinished_Business" has just caused a CPU exception.
You should not use that study until it has been updated to solve the CPU exception error. You can also run in Safe Mode to block all 3rd party studies from being used. Refer to the following: Sierra Chart - Software Login Instructions: Using Safe Mode For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
