Date/Time: Tue, 25 Feb 2025 11:45:46 +0000
Getting Trade Order status with ACSIL
View Count: 1361
[2021-04-13 11:27:07] |
PS2004 - Posts: 47 |
What function should I use to determine if there is currently an active Order?
[2021-04-13 13:54:04] |
You need to iterate through all the orders and check the status of them: Automated Trading From an Advanced Custom Study: sc.GetOrderByIndex And refer to: Automated Trading From an Advanced Custom Study: Determining the Status of an Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-13 13:54:10
