Date/Time: Tue, 25 Feb 2025 11:18:29 +0000
Weekly TPO profile
View Count: 1053
[2021-04-12 23:08:28] |
Steve Leon - Posts: 308 |
I am trying to create a weekly TPO profile. I have played around with the session times, Time periods etc... For some reason the profile is starting on a Saturday and ending on a Saturday. Not really sure why it is set up this way ? I am trying to get it to display from Sunday to Sunday date along the bottom. I looked on Google/internet and previous support boards but these did not help Any suggestions. I am no trying to do anything fancy. Just weekly profile of ES from Sunday to Sunday Thank you Steven Leon |
[2021-04-13 04:28:27] |
Sierra_Chart Engineering - Posts: 18555 |
For some reason the profile is starting on a Saturday and ending on a Saturday. Not really sure why it is set up this way ? This is because of reversed Session Times. Refer to:Chart Session Times: Bar Starting Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
