Date/Time: Tue, 25 Feb 2025 11:06:55 +0000
How to get the CBOE VIX (S&P500) and VXN (Nasdaq)
View Count: 796
[2021-04-12 17:53:14] |
mbilyanov - Posts: 62 |
Hi, I went through the various documentation but I'm still not sure how to add the data for the following indices: * VIX (S&P500) * VXN (Nasdaq) Ideally, I would like to do that without messing up my current subscription of oversubscribing to services that I don't need. Could you please help me to figure this out? I'm using Denali and IBKR for execution. Thanks, Milen |
[2021-04-12 20:20:06] |
John - SC Support - Posts: 38150 |
Both of the listed symbols are part of the CBOE Indices. To get this data, you would need to use the Sierra Chart Exchange Data Feed and activate the CBOE Indices exchange. Refer to the following Setup Instructions: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions This is a separate data feed from the Denali Exchange Data Feed, so it has its own set of fees. You can use both the Sierra Chart Exchange Data Feed and the Denali Exchange Data Feed together and with any of the trading services we support. If you follow the instructions and only activate the CBOE Indices, you will be fine. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
