Date/Time: Sun, 27 Sep 2026 20:02:53 +0000
[User Discussion] - accessing CFCO_VOLUME_BASED_ROLLOVER
View Count: 1033
[2021-04-12 16:49:25]
User785302 - Posts: 8
Hello
In the study that I am writing, I would like to know if the Chart is using the setting "Continuous Futures Contract - Volume Based Rollover". I believe this is the enum below as in scconstants.h.
enum ContinuousFuturesContractOptionsEnum
{ CFCO_NONE = 0
, CFCO_DATE_RULE_ROLLOVER = 1
, CFCO_VOLUME_BASED_ROLLOVER = 2
, CFCO_DATE_RULE_ROLLOVER_BACK_ADJUSTED = 3
, CFCO_VOLUME_BASED_ROLLOVER_BACK_ADJUSTED = 4
, CFCO_FORWARD_CURVE_CURRENT_DAY = 5
, CFCO_ROLLOVER_EACH_YEAR_SAME_MONTH = 6
, CFCO_FORWARD_CURVE_STUDY_SUPPORT = 7
If I would be able to read the setting then I could log an error message sc.AddMessageToLog(true) to alert the user that the study is not going to work well without that setting active.
Is this possible?
Kind regards
[2021-04-13 05:21:20]
Sierra_Chart Engineering - Posts: 24992
Refer to:
ACSIL Interface Members - Variables and Arrays: sc.ContinuousFuturesContractOption
[2021-04-13 06:50:24]
Thank you for the quick reply. Embarrassingly, I really thought to have searched all the documentation before hitting you up but there you go, I totally missed that. Thanks!
Apart from that, for info...checking if it's a futures contract.
I tried to use sc.SecurityType() to check if it's a futures contract but the function returned null. As a workaround, I am checking if sc.ContractRolloverDate > 0. Seems to do the trick for now.
