Date/Time: Tue, 25 Feb 2025 11:00:19 +0000
5 second Data Delay
View Count: 486
[2021-04-12 15:23:15] |
jaxscott - Posts: 57 |
I'm getting a consisten DD of 5 seconds. Why is this and is this a problem? Denali Data with CQG order routing...
[2021-04-12 18:36:39] |
John - SC Support - Posts: 38150 |
Generally, it is not a problem. Usually it just means that your computer clock is off by 5 seconds. If you want Sierra Chart to check and update your computer System Time, then refer to the following: General Settings Window: Periodically Set System Date-Time from Server (Global Settings >> General Settings >> General >> Update Intervals) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
