Date/Time: Tue, 25 Feb 2025 11:17:50 +0000
How to totally delete lines drawn via s_LineUntilFutureIntersection
View Count: 649
[2021-04-12 08:59:16] |
User275592 - Posts: 97 |
Hi, I am using your very powerfull LineUntilFutureIntersection feature in an acsil program. The lines are drawn and "cutted" by the candle when the price hits them I'd like to delete totally those lines when the price intersects them can you help me doing that ? Thank you very much |
[2021-04-12 17:05:40] |
John - SC Support - Posts: 38150 |
You would need to keep track of when the line intersects and then use the following function to delete it: ACSIL Interface Members - Functions: sc.DeleteLineUntilFutureIntersection() For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-12 17:55:19] |
thank you very much ! sierrachart = great software + great support !
