Date/Time: Sun, 22 Dec 2024 13:48:07 +0000
[User Discussion] - Delta accumulated on a zigzag
View Count: 1993
[2014-03-06 22:06:25] |
User56304 - Posts: 33 |
Is it possible to measure cumulative Delta across zigzags? I'd like to plot Delta per Price tick across zigzags. This would be the accumulated delta between the last zigHi and the current zigLo (or vice versa) divided by the price range between the zigs in ticks. Ideally, the output would be numeric and sit atop the zigzag range #, but if it's only possible on a lower chart region I'll take it wherever I can get it. Thanks. |
[2014-03-10 23:11:37] |
Is there a reason why this post is categorized as User Discussion?
[2014-03-11 00:02:16] |
Sawtooth - Posts: 4141 |
Have a look at this thread on the old forum: http://www.sierrachart.com/supportboard/showthread.php?t=33108 |
[2014-03-11 02:53:00] |
Thanks, Tom. Very interesting dialog and a wonderful spirit of generosity here. jsyd's offering is close to what I'd hoped to find. I'll sniff around to find someone who would know how to modify the cpp to divide his output by the # of ticks in the zig. And now, this is appropriately enough, a User Discussion. ;) |
[2015-04-30 12:30:21] |
Acro - Posts: 441 |
User56304 and tomglib, did you ever do that amendment to the cpp file. I have looked at the code and tried to have it print before the close of the current bar. However, it is compiled with a previous compiler version and does not compile with the current version of Sierra |
