Date/Time: Tue, 25 Feb 2025 10:39:37 +0000
Data Delayed PRO - CME - should be live
View Count: 582
[2021-04-11 22:31:56] |
DayTraderEsad - Posts: 121 |
I have restarted the computer , and tried to changed servers from 1 to 2 to be primary. I have deleted and redownloaded all data. Data is delayed still. I have also disconnected and connected multiple time and it keep being delayed. Can you look into this please?
[2021-04-11 22:51:08] |
h0408365 - Posts: 14 |
Same here, not getting any data for ES
[2021-04-11 23:18:35] |
Data is live, but it is missing data from 15:33: 15:56 PST - It is missing data across all products ES, NQ, RTY which is affected the calculation of the studies on the chart. I have attached a zoomed in snapshot so you can see the missing times.
Date Time Of Last Edit: 2021-04-11 23:19:46
[2021-04-12 01:41:06] |
Refer to this post here regarding this and the missing data: Denali Data Feed CME Group Market Data Feed Interruption - Some Servers First Hour 2021-04-11 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
