Date/Time: Tue, 25 Feb 2025 10:17:14 +0000
Market data is not updated.
View Count: 837
[2021-04-11 22:29:15] |
KingAB - Posts: 20 |
Some of the symbols are not loading Denali data. Here is an example: ES, MES, CL, NQ, RTY do not work. YM, MYM, ZN seem to work.
Date Time Of Last Edit: 2021-04-11 22:50:43
[2021-04-11 22:30:13] |
User208416 - Posts: 39 |
same thing here. Denali is active but DOM is frozen.. no data is coming through
[2021-04-11 22:34:42] |
Did it just start happening for you? Or did you renew as well?
[2021-04-11 22:36:17] |
no renewal. Data is delated and DOM is completely blank. I did not renew anything
[2021-04-11 22:42:29] |
I see. It looks like it may be related to some products. For example ES, MES, CL, NQ, RTY do not work. YM, MYM, ZN seem to work.
[2021-04-11 22:47:59] |
h0408365 - Posts: 14 |
Having the same issues. ES is not updating live. Support?
[2021-04-11 22:50:37] |
User753428 - Posts: 167 |
same experience here on the exact same products as you described. not getting NQ ES RTY but getting YM. |
[2021-04-11 22:51:43] |
Glad I'm not the only one. I have updated my first message to simplify the message. Support, are you aware of this issue?
[2021-04-11 22:56:56] |
Seeing something coming through now after disconnecting and connecting again.
[2021-04-11 23:01:34] |
BubbityDog - Posts: 8 |
Edit: Working now. I guess the issue was resolved server side. Same problem here... no symbols work for me (not even YM, ZN). I was working on troubleshooting by creating a simple chartbook in a single instance and a single data connection to Denali only (and was going through this page: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart: 3.9 - Options that Disable Chart Updating) but it still wasn't working, so I'm glad someone posted here. Other than updating to 2247 I hadn't really done anything environmentally since Friday when it was working last. The Status Bar numbers are incrementing like there is data flowing but realtime charts (e.g. footprint) are not updating and the DOM is blank. There are no errors in the Message Log but I do see things like "HD Request # 28 | Received 0 records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for YMM21-CBOT | 2021-04-11 15:56:31.836" Date Time Of Last Edit: 2021-04-11 23:08:50
[2021-04-11 23:54:45] |
User256155 - Posts: 19 |
Read the sticky at the top of the board
[2021-04-12 01:48:19] |
Refer to this post here regarding this and the missing data: Denali Data Feed CME Group Market Data Feed Interruption - Some Servers First Hour 2021-04-11 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
