Date/Time: Tue, 25 Feb 2025 10:16:25 +0000
IB TWS API
View Count: 669
[2021-04-11 17:10:21] |
UserOne - Posts: 40 |
I read that people are unhappy about the IB TWS API. Now I found a new version being developed. In case SC is not following IB news, I like to make you aware of it. Most likely you know that already. Anyway. The API uses a standard swagger format compliant with the OpenAPI 2.0 specification for RESTful APIs. https://interactivebrokers.github.io/cpwebapi/ I just hope that this is a good thing and that the new API together with the Denali Feed will make us (IB) trader and SC support happy. |
[2021-04-11 17:44:48] |
Ok we will have a look at this, but with our development schedule we really do not see getting to it for some time. Would be very doubtful we would be able to do anything until towards the end of the year at the soonest .
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-11 17:44:55
