Date/Time: Tue, 25 Feb 2025 10:28:44 +0000
Way to output alert manager /LOG to .csv or .txt continiously?
View Count: 669
[2021-04-11 16:12:01] |
HeyUgly - Posts: 251 |
hello wanting to see if its possible to set my alert manager , which has alerts going all day with my system to an .csv, .txt that i can use to build an alert bot for my small room. |
[2021-04-11 17:10:36] |
Yes. You need to enable this setting: General Settings Window: Save Alerts Log to File (Global Settings >> General Settings >> Log >> Log) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-11 17:11:22
