Date/Time: Tue, 25 Feb 2025 14:28:30 +0000
how to reconstruct the maximum profit and loss data
View Count: 613
[2021-04-11 15:55:16]
d9e5c763 - Posts: 109
the sc docs mentions "In the case of non-simulated trading, Sierra Chart must be connected to the data feed to update the High Price While Open and Low Price While Open fields."
but after I accidentally deleted the TradeActivityLogs folder and tried to reconnect to the trading service, I checked the trade activity log and found that only MES had maximum profit and loss data,MNQ and M2K did not(show 0). Is there a way to rebuild this data? I use SC Futures Order Routing Service
Date Time Of Last Edit: 2021-04-11 15:58:56
imagedoc_2021-04-11_23-58-19.png / V - Attached On 2021-04-11 15:58:50 UTC - Size: 23.81 KB - 234 views
[2021-04-13 05:27:36]
Sierra_Chart Engineering - Posts: 18555
No there is not currently. We expect this information will be saved on the server with the upcoming CME direct order routing.
[2021-04-13 08:23:17]
if I want to get the correct data, does the program have to be kept open now
[2021-04-16 18:34:20]
today I deliberately did not close sierrachart during the opening and closing a position. I found that the high/low price during position numbers are still all 0. If the direct route of CME goes online in the future, TT will follow up and join this function?
