Date/Time: Tue, 25 Feb 2025 11:21:25 +0000
How to check how many contracts I can buy with my funds
View Count: 600
[2021-04-11 08:13:23] |
michal51525 - Posts: 5 |
Hi, can you please tell me how can i check in sierra chart how many contracts can I buy with the money I have on my account. For example if I have 1000$ on account how to check how much I can buy. And also I want to ask how can I buy micro lots or just part of contract, like for example I just want to buy contract for 100$. TY. |
[2021-04-13 05:25:44] |
Sierra_Chart Engineering - Posts: 18555 |
This depends upon the margin requirement . You need to contact your broker about this. If you want to trade a micro contract just be sure to use the correct symbol. Refer to: File Menu: Find Symbol (File) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
