Date/Time: Tue, 25 Feb 2025 10:23:53 +0000
VS compiler
View Count: 689
[2021-04-11 03:35:54] |
User253911 - Posts: 1 |
SC ver 2247 64bit when compiling C++ code, it comes with error: C:\SierraChart\ACS_Source>call "C:\Program Files (x86)\Microsoft Visual Studio 14.0\vcvarsall.bat" amd64 '"C:\Program Files (x86)\Microsoft Visual Studio 14.0\vcvarsall.bat"' is not recognized as an internal or external command, operable program or batch file. to fix it you need to change the VisualCCompile.Bat C:\WINDOWS\system32\cmd.exe /C "C:\SierraChart\ACS_Source\VisualCCompile.Bat" to: C:\WINDOWS\system32\cmd.exe /C "C:\SierraChart\ACS_Source\VC\VisualCCompile.Bat" Date Time Of Last Edit: 2021-04-11 13:32:41
[2021-04-11 19:31:38] |
Update to the latest prerelease of Sierra Chart to solve this: Software Download: Fast Update Make sure it is the prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-11 19:31:46
