Date/Time: Tue, 25 Feb 2025 10:37:21 +0000
VbP Study help
View Count: 1078
[2021-04-11 02:07:33]
User628616 - Posts: 132
Using the VbP study, how do I get it to just display the Volume in gray bars per price level instead of the actual number(500×233), I included pics. Gray chart is how it currently is and Black chart is how I want it to display
imageScreenshot_20210410-210053_Gallery.jpg / V - Attached On 2021-04-11 02:03:19 UTC - Size: 557.76 KB - 292 views
imageScreenshot_20210410-205657_Edge.jpg / V - Attached On 2021-04-11 02:03:29 UTC - Size: 477.14 KB - 233 views
[2021-04-11 11:52:55]
Ackin - Posts: 1865
https://twitter.com/Trade_Your_Plan
- instructions on twitter and on youtube how to do it
https://twitter.com/TicinoTrader
- already ready solution to download if you are a subscriber his charts
[2021-04-11 12:38:27]
I didn't see anything on YouTube for trade your plan video on it.
I just want to remove the bid × ask numbers from the candle
[2021-04-11 12:49:58]
Ackin - Posts: 1865
My post was to your second picture (kissorderflow) and the same was created by both of the above ...
If you use a miltiaple VbP profile for it, try:
Display Volume in Bars (In46) ....(inside VbP study settings)
Volume By Price Study: Display Volume in Bars
Date Time Of Last Edit: 2021-04-11 12:56:15
[2021-04-11 16:21:32]
I found the solution, and here is the end result: As of now.
imageschelp.png / V - Attached On 2021-04-11 16:20:54 UTC - Size: 63.33 KB - 219 views
[2021-04-11 18:52:27]
Ackin - Posts: 1865
Great .... There are only two ways.
1) Use multiple volume profiles .... and do not display in VbP numbers via Input 46 as I wrote above
2) Set the volume profile to the third column of the Numbersbar
Sierrachart does not offer other options. The second variant offers, in addition to the volume of the profile, also highlight imbalance directly in the profile ....
