Date/Time: Wed, 27 Nov 2024 07:43:29 +0000
Make Footprint Chart chart show delta like this
View Count: 2223
[2021-04-11 00:48:57]
User912175 - Posts: 9
Hey guys I’m trying to figure out how to show delta on my footprint like shown in the picture I attached can’t figure it out in the studies settings
Private File
[2021-04-11 09:52:07]
58LesPaul - Posts: 429
This is the User Discussion Board, we can't see the attachment if you meant for other SC users to help. But if this was meant for SC Support you need to post in the SC Support board.
https://www.sierrachart.com/SupportBoard.php
[2021-04-21 21:35:19]
John - SC Support - Posts: 36309
We apologize, somehow this slipped through.
In order to show the delta like you have in the picture, just set the Column 1 Numbers Bars Text to Ask Vol Bid Vol Difference or Ask Vol Bid Vol Difference Diagonal. Refer to the information within this section:
Numbers Bars: Numbers Bars Text Types
You would then set the Column 2 Numbers Bars Text to Ask Vol x Bid Vol in order to get the second column of data.
[2023-09-09 11:13:20]
User408639 - Posts: 69
Moin Moin.
Can we add a logarithmic scaling of these Δ-Bars, i.e.,same ratios-=^=same bar-height-differences.
Tschüß,
Michael Soliman.
Date Time Of Last Edit: 2023-09-09 11:14:16
[2023-09-11 14:42:59]
Refer to the following for how to make a chart logarithmic:
Chart Menu: Logarithmic Scale (Chart menu)
