Date/Time: Tue, 25 Feb 2025 11:25:25 +0000
A couple of issues.
View Count: 620
[2021-04-11 00:42:58]
Tr@der17 - Posts: 12
I'm having a couple of different issues I was hoping to get help with.
First of all, some of my charts aren't showing up when I do a chart replay. I am selecting "all charts in chartbook", and MOST of them are indeed syncing, but not my Numbers Bars chart, or my DOM ladder. Any thoughts?
Also, I'm doing the standard replay, but even when I'm not doing a replay, I find my computer lagging, especially after loading several symbols. I have a half-decent gaming laptop from a couple of years ago, so I shouldn't really be having this problem. It's even crashed a few times. Is there a way to reduce my CPU usage? I think I have "days to load" set to 9 on each of the charts, should I reduce that significantly, and/or is there something else I can do?
[2021-04-11 17:13:50]
This would relate to the Days to Load setting as explained here:
Replaying Charts: All Charts in Chartbook
For performance issues, refer to help topic 30:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
We need to know specifically what happened in this case. Also update to the current version:
Date Time Of Last Edit: 2021-04-11 17:16:23
[2021-04-13 04:22:32]
Thanks again for the help.
The smallest timeframe I tend to use is 15 seconds. I changed the Intraday Data Storage Time Unit from 1 tick to 1 second, and that seemed to make a big difference. Will this cause a delay in volume data or something? Would you recommend I go even higher?
[2021-04-13 05:31:40]
No.
Yes if you are not using variable timeframe bars.
[2021-04-13 05:41:41]
Sorry for the newb question, but what are variable timeframe bars?
I do have a tick and range bar chart in my main chartbook. Is that what you mean?
[2021-04-13 11:07:56]
Yes these are variable length bars. So it is fine to use an Intraday Data Storage Time Unit of 1 Second but not higher.
Date Time Of Last Edit: 2021-04-13 11:08:21
