Date/Time: Tue, 25 Feb 2025 10:28:06 +0000
Any ACSIL function to Uncheck Split-Records?
View Count: 514
[2021-04-10 14:25:31] |
ejtrader - Posts: 688 |
SC Team - Is there any sc function available to "uncheck" split records" option? Or if ACSIL function is not available - any global setting to uncheck when a new chart is opened? Thanks |
[2021-04-12 14:33:52] |
No this is not supported.
