Date/Time: Tue, 25 Feb 2025 10:03:27 +0000
DENALI Real Time Data
View Count: 616
[2021-04-10 05:26:23] |
User580470 - Posts: 8 |
Hi, I recently signed up for Denali Real Time Data and I wanted to make sure that I have it setup correctly. I've been using Denali for about a week now and I really didn't notice a difference between that and CQG connection I had with AMP. So I wanted to see, if possible, you can look up my account setups? Thank you! |
[2021-04-12 14:29:30] |
John - SC Support - Posts: 38150 |
Everything looks good on our end. Refer to the following which ensures that you will get the data from us and gives you the information on how to verify that you are getting data from us: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
