Date/Time: Mon, 21 Sep 2026 21:49:33 +0000
Need assistance with data feeds/billing
View Count: 666
[2021-04-09 17:41:11]
User559224 - Posts: 22
Forgive me, but there is a lot of data to go over and I don't think I have thing set right. I am with Amp futures and I want to have access to equities. I don't recall it ever being this expensive and I may have selected something I shouldn't have.
I'm paying for SC + Denali data feed which is 36/mo + 3.25 Exchange feed?
I thought I would just add the 10.50 equity feed, but it looks like i'm paying 25.00 for a first connection for 250 symbols. I don't need this as I'm only going to look at one symbol at a time, or is that not possible? i've done this before and it seemed to have work with just the feed itself.
[2021-04-09 18:29:10]
John - SC Support - Posts: 47955
You have everything setup correctly.
The Sierra Chart Exchange Data Feed does work on the number of symbols you will be getting data for concurrently. The minimum number you can set is 250, which sets the cost for the Sierra Chart Exchange Data Feed itself at $25.00. Then you have the additional exchange fees.
