Date/Time: Tue, 25 Feb 2025 10:05:24 +0000
Manual VBP Volume by Price extension
View Count: 550
[2021-04-09 16:52:23]
User648702 - Posts: 48
I use a 1 minute chart and manually use the vbp study for certain current sections. I have been frustrated because the study was not extending to the right to cover current price and I had to keep extending manually (usually too late before I noticed that the vbp was not long enough anymore).
I found where I can extend the study to the end of day which would work for me but I am not able to save this setting as a default. When I go to use it again, it has defaulted back to fixed time. My other defaults that I have saved are saved but the volume graph period type will not save as my default.
It would be nice to be able to save multiple profiles as defaults like other studies.
Thank you
[2021-04-09 18:24:58]
John - SC Support - Posts: 38150
We just checked and we are not having any problem saving the defaults with different values in the Volume Graph Period Type.
Although we would be surprised if there is anything that changed related to this in a recent version, but update to the current version in order to make sure, and see if you still have the same problem.
