Date/Time: Tue, 25 Feb 2025 14:04:17 +0000
Denali Exchange Data Feed for futures markets?
View Count: 1311
[2021-04-09 16:20:38] |
User925138 - Posts: 22 |
Is the Denali Exchange Data Feed available for futures markets? YM, ES and NQ?
[2021-04-09 18:01:26] |
John - SC Support - Posts: 38150 |
Yes. The Denali Exchange Data Feed has data from The CME Group and EUREX. Refer to the following: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-15 05:05:17] |
Trading the futures markets as a non-professional? YM, ES and NQ. Which option should I activate for the Denali feed? Thanks, -Kevin |
[2021-04-15 14:21:57] |
First, make sure you are aware of the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges It looks like you are using TransAct, in which case you will have the qualification of having a trading account for the CME Group. As to which exchange to activate, we need to know if you use Market Depth or not? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-15 14:52:33] |
Yes, I use TransAct or Infinity for futures trading. The TransAct dom shows me 10 above and 10 below ask/bid. Want to be able to see more in both directions. Not sure if that is Market Depth or not. Thanks for your time and effort. I've been trading futures since 2011. But don't know all the terms, I supposed if I began teaching others how to trade I'd have to learn the lingo, but I don't. -Kevin |
[2021-04-15 16:12:46] |
The ES and NQ are on the CME Exchange and the YM is on the CBOT. The numbers you are referring to is the Market Depth. With the Denali Exchange Data Feed you will see up to 1400 levels. Therefore, the cheapest option would be the following two exchanges if you just need those 3 symbols: - CME with Market Depth for nonprofessional trading accounts: $10.40 - CBOT with Market Depth for nonprofessional trading accounts: $10.40 Follow these instructions to setup the Denali Exchange Data Feed: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-17 16:46:01] |
I'm trying to activate "CME with Market Depth for nonprofessional trading accounts: $10.40" But I keep going in circles and I'm not getting anywhere " - To activate the Denali Data Feed you need to change the current Service Package to a Service Package that includes the Denali Data Feed." "Active Service: 1 Additional System - Active until: 2021-05-14 23:59:59 UTC Each additional system will allow you to run the Sierra Chart software on an additional computer. 2 systems are included." 2 systems are enough. I need help. -Kevin |
[2021-04-18 01:22:51] |
In your case to be able to activate the exchange we need to change your Service Package to 10. This is 36 USD per month. Shall we do this for you? Or you can do it: To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-18 01:23:25
[2021-04-18 13:30:35] |
"This is 36 USD per month. Shall we do this for you?" Please do. Thanks, -Kevin |
[2021-04-18 20:08:02] |
This is now done.
[2021-04-18 22:58:14] |
I opened my Infinity/Transact futures dom and only see 10 above and 10 below.
[2021-04-18 23:53:23] |
The Denali Exchange Data Feed only works within Sierra Chart. It will not work within the Transact trading software. Sierra Chart does have its own Trading DOM you can use. Refer to: Chart Trading and the Chart DOM: Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
