Date/Time: Tue, 25 Feb 2025 10:03:56 +0000
is there a way to disable evening session by default?
View Count: 628
[2021-04-09 16:10:28]
User735389 - Posts: 189
this setting doesnt seem to be saved to the chartbook. everytime i open it loads the evening session and i have to disable it (my main is to look at the active session and switch to evening session sparringly)
[2021-04-09 17:52:13]
John - SC Support - Posts: 38150
The selected status of the Evening Session is definitely saved with the Chart in the Chartbook. So if you save a Chartbook and open it up again, that status will stay the same.
You should just establish a "template" chart that you can copy to create the chart the way you want. Refer to the following:
Using Chart Templates: Duplicating Charts / Template Charts
[2021-04-09 18:06:00]
ah you're right. i forgot i setting the evening session times (and that check box) through acsil. thnx
