Date/Time: Tue, 25 Feb 2025 10:02:11 +0000
disconnect indicator line between sessions
View Count: 541
[2021-04-09 07:17:59] |
Channas - Posts: 32 |
Is there any way to disconnect (so it creates gab instead) an indicator line between sessions(days)?
[2021-04-09 15:14:08] |
John - SC Support - Posts: 38150 |
Use the draw style of Dash instead of Line. Refer to the following: Chart Studies: Dash (ACSIL: DRAWSTYLE_DASH) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-09 21:56:48] |
Also refer to: Chart Studies: Avoiding Vertical Joining Line for Study Subgraphs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-09 21:57:30
