Date/Time: Tue, 25 Feb 2025 10:18:54 +0000
Feature Request: Chart Values for Tools Window
View Count: 561
[2021-04-08 21:07:46]
User275839 - Posts: 61
Hi -
I've been working on developing studies using the SC ACSIL framework, and frequently use the "Chart Values for Tools" window when debugging. I'm finding that it would be helpful to have the bar index value for the bar under the crosshairs always show up in the tools value window. Maybe at the top of the window where the Y val is always shown?
I checked the new "Tool Settings Window" but couldn't find anything that looked like what I wanted.
Thank you for considering this request!
[2021-04-08 21:31:21]
John - SC Support - Posts: 38150
One of the tools we use is the "Bar Numbering" study. It is offset by 1 typically, due to a zero-based array, but as long as you know that going in. Refer to the following:
Bar Numbering
[2021-04-09 19:55:09]
I checked out the Bar Numbering study. Thank you for pointing it out! I will experiment with using it to assist in debugging.
