Date/Time: Tue, 25 Feb 2025 09:56:17 +0000
Consolidation of accounts Account No. 21284
View Count: 471
[2021-04-08 20:33:17]
mdressel - Posts: 12
I received an email from you on April 7 indicating that I had 2 Sierra Accounts i.e. mdressel and Transact_User_mdressel. You indicated that if I wanted to use the Transact account, I could consolidate the mdressel account into the Transact acoount. My question is will this cost me extra money? If not, just consolidate the accounts. Mark Dressel
[2021-04-09 02:22:48]
No we can do this for you right now. We will take care of that.
[2021-04-09 02:27:18]
Sierra Chart - Max - Posts: 5793
1. TransAct_User_mdressel has only 2 days of usage time on it. We recommend that you continue using mdressel as it has 2 weeks of usage time and the Denali data feed with CME data.
We have also extended your direct account by 2 days of usage time.
2. Also regardless of which Sierra Chart account you will be using to receive real-time CME data through the Denali Exchange Data Feed when using the lower-priced CME exchange fees which are enabled on your account, requires that you connect Sierra Chart to your live trading account at least once a month.
For instructions, refer to:
Sierra Chart Support
Date Time Of Last Edit: 2021-04-09 02:28:48
[2021-04-09 12:47:13]
Thank you. After the consolidation do I still have to connect my Sierra account to my trading account once a month? Mark Dressel
[2021-04-09 15:26:16]
John - SC Support - Posts: 38150
If you are not going to be staying connected to your trading account at all times, then yes, you will need to connect at least once a month. Refer to the following:
