Date/Time: Mon, 25 Nov 2024 21:50:20 +0000
data services
View Count: 1215
[2014-03-06 18:05:36] |
User28317 - Posts: 149 |
i just signed up for package 5. i couldn't find the proper data package in the list for real time data on futures. I was able to pull up the s&p500 but not the futures ES
[2014-03-06 18:41:51] |
Refer to this section here: http://www.sierrachart.com/index.php?l=doc/data.php#FuturesData Do you use DTN IQ Feed? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-06 19:26:04] |
No, I use your intraday data. Are not future data sources avail.? |
[2014-03-06 22:05:07] |
Do you have a futures trading account with a broker? Did you want data for CME futures? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
