Date/Time: Tue, 25 Feb 2025 08:24:23 +0000
Volume based indicator question
View Count: 441
[2021-04-08 19:44:11] |
User31044 - Posts: 33 |
I currently plot volume and a 10 period EMA on top of that volume. I would like a simple indicator that plots Volume/10EMA. For instance, the current 5 minute bar on CL has a volume of 177 and the EMA is at 685.77, so my new indicator would display 0.258### for however many decimals I decide to use. I would like to plot it as a bar graph. Is this easy, or is there already an indicator that can do this?
[2021-04-08 21:02:12] |
John - SC Support - Posts: 38150 |
Refer to the following: Using the Basic Arithmetic Studies For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
