Date/Time: Tue, 25 Feb 2025 07:54:00 +0000
TOTAL
View Count: 470
[2021-04-08 17:27:50] |
User344478 - Posts: 157 |
When I "OPEN MARKET DEPTH WINDOW" how can I change "TOTAL" in brackets of Bid Price and Ask Price ?
[2021-04-08 19:05:37] |
John - SC Support - Posts: 38150 |
You can not change that. That is the total number of levels being shown. If you want to limit the number of levels that are coming into the system, then refer to the following: https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#MaxDepthLevels Note the information in the above about limiting on a Per Symbol basis and also limiting the number of levels displayed. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
