Date/Time: Tue, 25 Feb 2025 08:21:31 +0000
Updated and Cannot Build
View Count: 461
[2021-04-08 14:08:11] |
maxpi - Posts: 181 |
I updated from ver 2245 to 2247 and am assuming that caused the following problem. When I select Analysis-Build-Build With C++ I get the following error message: C:\SierraChart\ACS_Source>call "C:\Program Files (x86)\Microsoft Visual Studio 14.0\vcvarsall.bat" amd64 '"C:\Program Files (x86)\Microsoft Visual Studio 14.0\vcvarsall.bat"' is not recognized as an internal or external command, operable program or batch file. I reinstalled the Visual C++ compiler to no avail |
[2021-04-08 22:46:35] |
Sierra_Chart Engineering - Posts: 18555 |
ok we know why this happens. We will resolve.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-08 22:46:40
